Fuel psi. ?
Bobs rare 6
If running a double pumper with just one pump hooked up, would ther be a few psi. drop in fuel under boost? Wonderd if it can back bleed through other pump. Thanks, Bob.
when the boost equals the turn on point of th 2nd pump then there is now way for a pressure drop. But before the required boost it might be possible, but not much I would imagine.
