Fuel pump failure
Santos Moreno
Over the weekend my fuel pump failed on me, a buddy turn the ignition while I smack the pump and we got it to run. I usually can hear the pump running, now it sounds weak and car feels like caca. This is the external pump at fault. What would be a good replacement since Im only taking the car one more time for a 200 mile run and then its going dormant for the rest of the year. I do want to go to E85 over the winter. Any recommendations or alternatives in pumps, I am on a semi-limited budget so I need something in the middle of the road. Only modest upgrades TE44, mototron 60 inj, RJC plate, Pypes exhaust, powerlogger, electric cutout, 3' THDP, 9.5 NL PTC, LS1 maf, translator II.....with E85, bigger turbo, 80 inj, and diff heads
If you're using E85 you're going to need a lot of pump, injectors, fuel line, return line, and I would use a Weldon pump.
