Hey, thanks Craig, I got the fuel straightened out and the fan was my next task. Thanks for the info. If anyone wants to know how to wire up the relay, I'll try to explain it the best I can. Here goes: First get a standard bosch relay. Next find wire S3 on the fast harness and run a wire from #85 on the relay to this wire, Don't cut any wires, just tap into all of these. I soldered my wires onto the fast harness right at the connector. 2 can go directly to the board on the fast harness and 2 will solder onto the wires themselves since there is'nt room on the board. Next find Buick wire A6 (it's marked on the plastic factory ecm connectors) then find this same wire on the on the fast harness and run a wire from #86 on the relay to this wire. Again, solder it in no butt connectors or cutting. Next find Buick wire A1 (factory connector) then find it on the fast harness and run a wire from #87 on the relay to this wire and solder together. And last, find Buick wire C16 then find it on the fast side and run a wire from #30 on the relay to this wire and solder. Tape everything back together and make sure stock relay is still hooked up and then turn on the key. You have fuel! Hope this helps.
