Got a problem with 97.5 V6 3800 Supercharged Regal.
1.) Car Was running but stalled out the other day.
2.) When ignition is turned on, car starts and runs fine for a few seconds and then stalls out again.
3.) Seems like a fuel pump problem but you can hear the fuel pump turn on when you turn on the ignition. Bought a fuel Pump and changed it - No dice.
4.) Car will stay running if you keep pumping the accelerator to the floor repeatedly but soon as you try to idle or throttle it down -- it dies.
5.) Thought it could be a relay so I bought one and swapped them out - no dice.
6.) Tried a fuel filter, motor ran for about 45 seconds fine then did the same thing.
7.)Bought an Idle Air Control and swapped that out - no change.
8.) Checked the fuel and it is fine.
9.) Have AutoTap and plugged in and found no significant DTCs.
10.) Have ordered a Ignition Control Module and a Fuel Sender resistor kit. Those will come in a day or so. Hoping to send the ICM back - that's $205 more than I need to spend.
It starts up just fine -- normal start-up. Runs for a couple seconds and then dies as if the ignition were just shut off. No coughing or sputtering or anything unusual. After it dies, the fuel pump starts up just like it should. Every time you turn on and off the ignition, the fuel pump starts up for the 1 or 2 seconds. When you turn the ignition to start, it will do it all over again -- Startup, run for a few seconds, shut down.
If you try pumping the accelerator, motor will run as long as you are flooring it. Plus, there is a rev-limiter on this so when you hit the peak RPMs, it backs off the fuel until it is below RPM Limit. But again, as soon as you try to come back down to normal idle or RPMs, it just shuts down.
Any techies out here have any ideas as to what to check next? I have Service manuals for this motor but they seem pretty vague on what to test. All hoses and connections appear in order upon visual inspection. Haven't tested fuel pressure other than readings from AutoTap. It doesn't seem like that's the problem. The pressure is there. It's just after it starts running it just dies.
Thanks for any help.
