fuel pump problem
gn79
I need help! The problem is that my fuel pump is not working. I have replaced it and it still doesn`t work. I have put a new relay, I have hot wired it and it still doesn`t work. When I turn on the key there is no niose. I have pulled it out of the tank and pluged it up to the plug and it does work. When I put it back in the tank and hook it up it doesn`t want to work. I am thinking that there is a problem on the wire that is on top of the mounting plate. Can I rewire it from on top of the mounting plate to the fuel pump and them to the hot wire.
