Aug 26, 2012 #1 M mzunino Member Joined Jan 13, 2006 Messages 334 How long should the system stay pressurized after shut down? How long should It take to drop say 10 psi? I have rail gauge that has a small relief but seems to be leaking. What would you expect normally?
Aug 26, 2012 #2 H Hotrodbuick Member Joined Apr 17, 2012 Messages 273 Mine seems to hold pressure for a long time. Over night I know for sure. If the fuel pressure is leaking down might be leaking past the regulator. I'd check that first to make sure it's good. Stock regulator or aftermarket?
