Ok currently I'm feeding one side of the fuel rail from a -8 feed line. Have a BGC intake with the BGC fuel rails and a -8 crossover in the rear. I'm wondering if it might be a good idea to feed both sides of the rail at this point and up? I have 160 lb inj, turned down to about 35 psi fuel press and 145 lb/hr but am seeing low/mid 60's duty cycle on them, so the overall flow is starting to get up there. I guess that's about 550 lbs/hr or so. The pressure is holding steady at wot and 30 psi boost at the end of the rail, near the stock type regulator, but I dunno if there might be some funny dynamic stuff going on at wot. I like to try and keep things simple and stock appearing when I can, but anyone run into any related problems doing something like this? TIA!
TurboTR
TurboTR
