I wouldn’t get all crazy with the tank if you’re going to run gas. Now if you’re going to run e-85 then that’s different then yes an external pump may be needed and then you may want to just get a fuel cell in the trunk. Now for gas I would just use one of those new racetronics double pumper set ups with -8 to a speedway filter to the fuel rails. Now here you have some options you can either get some aftermarket rails or mod your stock ones if you can weld or have a friend that can do it for you If it was me I like the look of the aluminum rails so I would get a set of those form champion or one of the guys that do custom ones on here. If you want to save some coin mod your stock rails there are 2 ways to do this one is to replace the stock feed with a -8 fitting and for the return ether replace the shrader valve with a-8 or -6 fitting and run an external regulator or get one of the guys on here that makes the adaptor to run an external regulator off the stock regulator fitting. Or if I was going to mod a stock rail I would weld a -8 fitting on the back under the coil pack to feed the rails and then weld a -6 in place of the feed and the shrader valve then duel feed an external regulator, or feed with duel -6 and put the return off the back ether way would work. And since I brought up external regulators I know most guys go with the big brand name guys but I use the one Kerbin sells it’s awesome and you can’t beat the price tag on it. For house I just bought all Teflon house from anfittingsdirect . com run -8 feed to now for injectors if running gas 80s and a razor alky kit will do the trick , that’s more then what Grumpy has on Melissa’s car and it’s in the 9s. They run a single pump and 60s with alky on that car and it makes some high 9 runs.
My car is on e-85 I don’t plan on ever going much past low 11s high 10s and I’m sure I can handle the fuel for high 10s my new fuel system is a racetronixs sender with AN fittings a single DW pump and a boosta pump it then goes -8 to -6 and duel feeds a set of custom made fuel rails then duel feeds with -6 to a kerbin external regulator and I’m running 80 for injectors. If the car ever gets out of the paint booth maybe I’ll get to see how far I can push it this year.
