fuel system ?
GNSCOTT
open faced club sandwich
I was wondering if anyone else out there T's off the fuel line and sends seperate lines down both rails. If you do, i was wondering what you do abut fuel pressure guages. Do you run 2 guages?? 1 is enough??. My intake is set up with 2 fp regs ad i was planning on just keeping it that way, but now i am wondering..2 hood mounted guages might not look rght.Any thought would be appreciated....Scott
I chose not to run dual feeds, but if you choose to why not run a small crossover between the rails at the inlet fittings. There are fittings, normally intended to run a gauge, that allow you to do this by using the 1/8" gauge port: e.g., -8AN/-8AN/1/8" NPT. Then you wouldn't have to worry about running two gauges.
Art
thanks gys...looks like 1 reg. is the easiest way to go
