fully ported and polished stock heads
GNVAIR
ported 8445 casting iron turbo Buick V6 heads. These were ported by a friend of mine that has many years of experience with head work. All of the intake and exhaust runners are nicely blended into the bowls. The intake and exhaust ports were NOT enlarged as many people make the mistake of doing. The bowls have been blended and guides nicely tapered. The EGR ports have machined plugs to fill in the voids. The combustion chambers have been fully polished to eliminate any potential hot spots. The valve cover rails have been machined for a nice flat sealing surface to eliminate leaks. All worn guides repaired with bronze inserts. Decks have been milled and have the correct finish for use with Cometics gaskets. Manley 1.50 stainless exhaust valves and reconditioned stock 1.70 intake valves. Competition Cams 980 valve springs. New valve stem seals. Fresh multiangle valve job. These were bolted onto an engine, but have never been run. $750 shipped in the lower 48 states.
