Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
What boost? Was that with alky? Stock motor?Had to dig out some time slips, current is 69.90 69.98 and 70.38 mph on 3 dif runs, I'd like to change that to between 80 and 90 mph, but the motor and trans just can't put enough power down to do that in thier current state. Thats why I was kickin the ratio change idea around.
If you know the trap RPM, it will tell you what to do.
FWIW;
With ported heads and alky, you should be able to run 90 mph around 20 PSI, if you have the supporting mods.
