G80 Posi & Burnin Rubber
dsa87gn
I have the G80 option and when I stab my car from the light it will
get sideways, or a throttle stab on a left turn will get the driver
rear spinning.
On a brake torque though only the pass rear will light up. I have no rear suspension mods at all on this car. Does this seem normal or do I have a clutch problem.
Sounds like the posi is shot.
Even on ET Streets, I spin 'em both into big, puffy, white clouds of tire smoke.
S.
posi clutches are worn. Try changing the fluid. It may help a bit til you get it rebuilt..
Looks like Ill get a clutch pack on order..
Anyone been through this that knows of any other parts I should get while Im at it.
i'll burn one wheel for just a second then feel the posi grab, i'm going to change the fluid and only put 3/4 of a bottle of posi additive in it this time.
that might help you.
