g87 rear end ok???
sand1
looked at my rpo codes to see if car had posi but it doesnt it saig g87 with 3.42 gears so should i change it out for a posi traction(G80) or will it be fine the way it is
depends on what you are planning to do with the car. As a daily driver it will be fine if you want to do some drag racing you will want the posi. Either way it is stil the 8.5 rear so it is a good strong rear end.
so i can add posi to the rear end or do i need to switch the rear end out?
That's what I did. Get an Eaton posi from Gears are us.
