RKHiPerformance
Turbocharged Sex Cylinder
- Feb 25, 2003
FOR SALE
26x10.5" MT ET Drag Slicks mounted on 15x8" Weld Pro Star wheels. Pinned on both sides, static balanced, with MT tubes, center caps & lugs. Some street miles, still in excellent shape. Lots of passes left. $325/pair
KC-code 200R4 valve body: Modified for performance use by Level 10, fitted with Mallender transbrake. As seen in GMHTP, has gone 11.40's in Old Gray. Complete $250
(6) 43 lb 'Limetop' injectors: Like new, less than 2000 miles. $250/set
Extender chip also available, set up for these injectors and alcohol. Add $35
SMC Alcohol Injection Kit: Complete, no instructions $250
ATR 7th Injector Kit: Complete except for LED and kit instructions $50
Edelbrock Performer RPM intake manifold: for big block Chevy with oval port heads. Absolutely excellent - ready to install $165
LS1 cylinder heads: Removed from 2001 WS6 Trans Am with 17k miles. Assembled and complete - ready to install or ready for porting $200/set
Stock 15x7" steel wheels from 1984 Monte Carlo SS - Centers painted dark metallic blue, with trim rings and tired rubber. $75/set
Edelbrock Performer Series 750 CFM carburetor: with electric choke. Works perfectly with no leaks, hesitations or stumbles. Used for one year, about 1500 miles. $288 new, will sell for $185
Box speakers: Ultimate-brand truck speakers with 10" woofer and horn tweeter. Hardly used, perfect for truck, SUV, or shop use. $100/pair
SLP Air Temp Sensor Adapter - Fits between IAT and factory connector and modifies output from the IAT to read cooler incoming air. Adds 5-7 HP at WOT according to SLP as a result of increased timing. Fits '98 and newer LS1 with factory ECM tune. Absolutely like new. $15
Edelbrock Chrome Valve Covers: low profile design for big block Chevy. With breather, grommets and fasteners. $20
Please e-mail directly with questions or requests for pics:
RKHiPerformance@aol.com
No PM's, please.
Thanks,
Rick & Kristi
