gas smell
Lookin35
I smell gas when she is running. I smell it in when its running. It doesnt seem to be any leaks in the fuel line. the tank, fuel lines to the filter seems good. I think if it was leaking i would smell it everytime I go into the garage. The previous owner changed the injectors and chip. maybe and injector isnt instaled correctly?
Phil
If you don't see any visible leak from the fuel hoses, fuel line connections on fuel rail, injectors, regulator you can check the fuel vapor hoses at the charcoal canister. If the the vapor hoses are cracked/broken, you can smell the raw gas fumes.
