Gas Tank Fillerneck?
LSTTYPE
I am putting in a new gas tank in an 86 t type and I bought the tank and filler neck separate instead of together. How do install the filler neck! It looks like it presses in and then what? How do
I seal the neck to the tank? Can I solder around it like I've been advised to? Any advice is appreciated.
You could connect it with a silicone hose and 2 clamps like the up pipe in the engine. Many gas tank filler necks are connected that way.
Cool thanks. I just needed to know if soldering it was ok, I have no problem doing it since it's a new tank with no gas in it! Thanks again
Solder it, it's easy enough to do. :cool:
Don't forget to paint it or rust proof it. ;)
