ok, i am thinking of oing a stage motor but i have a few questions
1: what is involved in converting a dry sump engine to wet sump?
is this what the dutweiler oiling system does?
2: what oil pan do you use?
3: what front cover ?
4: i found a few short blocks that have broze bushed lifter bores, is this useable and what lifter is correct?
5: what about using blocks with needle bearings for the cam? can these be used with standard cam beaings?
6: gear drives? or chain(keeping in mind that it will be a street engine)
7: what pistons should be used? can you have the existing hi comp. milled for use in a turbo engine?
8: finally on or off center 4.1 or 3.8?(i know on center is easier to find) new or used?
