I have a B&M stacked plate trans cooler (#70266) that I will be installing this week. I want to keep my stock cooler inline with the external. My main question is what line should I tap into?
Ken Mosher's picture on the www.gnttype.org site shows the top line at the radiator running to the external cooler.
The other outlet on the external is then run to the top fitting on the radiator. It appears as if the lower cooler lines is left untouched.
Is this correct?
Is this correct?
