williambavila
William Avila (The Buick Guy)
- May 11, 2010
Power seat tracks $200 x2
Manual seat tracks $50 x4
Power brake conversion $200
86/87ecu $75 x2
Radio bezel $50
Dash bezel $75
Injector harness $40 x5
Fuel rail $45 x5
Stock throttle body $75
Upper plenumn $45
Stock reman cylinder heads ready to instal $450(shipped) set up for use with roller cam. X4 sets
109 block $750 std bore been checked and cleaned
2 center steel caps $265 (new)
Used arp head bolts $40 x4 sets
Used arp studs $60 x2 sets
.030 turbo crank $50
.010 turbo crank $125
Flywheels $25 x7
Seat belts a whole box including front shoulder belts $100
109 block has a crack below a freeze plug would work great with block fill half way std bore $250
Steering wheel needs re covered $100
Belt tensioner $75
Rear sail panels $25 a side x5
Rear quarter panel extensions $70 a set x2
B pilar trim $50 a set x4
Rear headliner metal trim $50
Package tray $100 x2
Package tray ends $25 x4 sets
Cam sensor caps $50 x4
Cam sensor $175
Fuel feed line to rail $65
Billit t stat housing $40
Stock valve covers $50 a set x2
Front arm rests $45 a set x2
Hard vacuum lines from tb set of 5 $75 x3
Stock timing covers $45 x4
Reman wiper motor $65
Stock oil feed line for turbo $25
Drain tube for turbo $40
Text me it's easier to reach me. 405-361-5362
Sent from my SM-N950U using Tapatalk
86/87ecu $75 x2
Radio bezel $50
Dash bezel $75
Fuel rail $45 x5
Upper plenumn $45
Flywheels $25 x7
Belt tensioner $75
Cam sensor $175
