Girdle on stock mounts
Razor
Forum tech Advisor
Staff member
Well.. dropped the engine in with a good 3/4 inch clearance .. actually too easy. Those that saw the oil pan mod on the other thread.. that did it.
Wonder if RJC could make a pan like this on limited production. I'd buy another to have on the shelf.
My dilema was running the taller PTE plenum which already hits the liner on the stockmounts.. then having had to raise the motor using the poly mounts/spacers as I know others have done. That would of been a big hood issue.
Here's the pix again.
Mounts used.. stock Pioneer replacements ;)
you have something against "cowl" hoods ?????? :rolleyes: ummmmm that other "thing" worked a LOT better!!!! :biggrin:
looks GREAT!!!!!!!!!!!
oh thats right,I got to help put it in.
had to be one of the easiest installs yet!!!!!!
time to tune!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks JD
