Stock modded motor located in WAUKESHA, WISCONSIN (zip: 53188) with everything needed to drop in a Grand National, T-Type or another car/truck/hot rod.
Price: $4500
Here is info and what is included:
* 2000 miles on freshened up motor. The plan was that I have as a back up motor but plans have changed. It has stock rods, pistons, crank, cam, heads (heads have been gone through) and lifters.
* All brand new gaskets - cometic oil pan gasket, intake, head gaskets, valve cover gaskets, front timing cover and every other gasket through out the whole motor.
* Newer timing chain
* ARP head studs
* Thicker rocker shafts
* RJC power plate
* 36lb injectors and matching chip
* Accufab adjustable fuel pressure regulator
* Fuel pressure gauge attached to fuel rail
* 62mm throttle body
* Good tested coil pack and ecm
* Newer MSD spark plug wires
* 160 thermostat
* Braided turbo return line
* Headers powder coated
* Good stock turbo with billet turbo inlet bell
* Good stock intercooler with intercooler shroud, brackets and intercooler fan blade
* Stock down-pipe
* Billet EGR block off (still have original EGR control valve and ERG sensor)
* Billet vacuum block (still have original vacuum block)
* New AC Delco spark plugs and oil filter
* Stock wire harness with all relays and sensors
* Stock computer with chip
* AC compressor delete pulley (or have stock AC compressor with AC lines and condenser if needed)
* Stock power steering pump with lines and the revisor
* Stock motor mounts with frame mounts if needed for a transplant in another vehicle
* K&N air filter with 3” inlet tube
Also I have the following items for more cost if you want more high performance parts items for this motor
* 3” ATR down-pipe with new Precision 38mm external waste gate
* Accufab polished dog house
* TE44 Turbo - very low miles
* Precision 6776 turbo (journal bearing) - powder coated inlet with very low miles
* Precision 60lb injectors with Turbo Tweak 93 chip
* Precision modded turbo oil filter relocation kit (the mod is replaced rubber line to braided lines) - 2 new oil filters included as well
* Action Fabrication stretched intercooler
* Stock 200r4 transmission with stock converter
Price: $4500
* ARP head studs
* RJC power plate
* 160 thermostat
* Stock down-pipe
![088b4d48e23dfbcb60a6e6e866aebe49.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190503%2F088b4d48e23dfbcb60a6e6e866aebe49.jpg&hash=27a0c286841eaa9c232b0e148492a3c8)
![cf8766b9f1afd0663b367549adc6b3fe.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190503%2Fcf8766b9f1afd0663b367549adc6b3fe.jpg&hash=f664202ea0950297401dab0fbbffde62)
![c6bb4cb4d49380f76f06a49cf947e7ee.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190503%2Fc6bb4cb4d49380f76f06a49cf947e7ee.jpg&hash=ea2edc9926348a3530b3832d1a36dfc9)
![0db2051a9e1a6a92749797125caaa528.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190503%2F0db2051a9e1a6a92749797125caaa528.jpg&hash=e94ea2a32a23f3b13c8d50551e3a26e9)
![fe1dbeaed8a6cb6bf976174d2f87dc3d.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190503%2Ffe1dbeaed8a6cb6bf976174d2f87dc3d.jpg&hash=74672da52d0c4eaa3995e2e02ee0c580)
