GM Temp sensors
Supercharged408
I have a Dodge running the FAST ECU, and the CTS calibrations for Mopars is just WAY off, I have made one that is closer to being accurate, but I have no way of testing it. So, my solution to this is to just use some GM sensors.
My question is, what GM sensor's are correct for the FAST, or are they all the same calibration? What is the most inexpensive ones out there if they are all the same calibration?
Damon
Originally posted by Craig Smith
If you would like to go that route, purchase sensors for a 1990 Camaro with a 350 and you will get what you need.
everything will work except the IAT sensor......you need one from a late model LT1 or a ZR1. The kind that has the holes in the sensor. At least this is what i have been told
