A 6109 block usually came in i think 85-87 models, to identify a turbo block you would have to see if the oil return boss is there for the turbo,also see if it has rollet fillets on crank for rods and mains,if only on mains it probably came out of a normally aspirated carb motor.i think 8445 heads are on from 84-87 motors.
