AS some of you will remember ... I had an 87 GN, bone stock, that would occasionally need to be towed home.
You all helped me attempt to fix this problem on my own, but when it wouldn't run period.... I took it to a GN mechanic.
Jus thought you'd all like to know ... turns out it was the EGR solenoid!
Car runs fine all the time now .... keep it in mind, since it didn't throw a code! Apparently, if you slide your hand UNDER the EGR valve and have someone brake torque the car you can feel if the valve moves up. If it doesnt, chances are the egr solenoid is bad. Cheap part.
Jus a lil tid bit of info!
