gn rear end cover
JC3569
Does any one have a aftermarket aluminum rear end cover for a 8.5 . thanx joe
can call also #774 930 4156
hello people; I just cleaned up my stock cover, painted it and added some chrome bolts. And the stock cover has a large magnet bonded to the inside.
What does a girdled cover suppose to do for you?
IBBY
Heres details from TA Performance girdles.We sell them with the HRpartsNstuff logo with bolts and gasket,you also can order stud kit for little extra.Heres the write up.
Specifically designed to add support to the bearing caps under severe loads and acceleration, these girdles substantially strengthen the rear end. They also add fluid capacity, which helps to lower the fluid temperature. Comes with drain and fill plugs for easy maintenance.
* All TA Girdles are made of 356 aircraft grade aluminum, heat treated to T6 specifications, each cover is then stress relieved.
* All Girdles incorporate a Fill Port and a Drain Port for ease of servicing.
* All Girdles incorporate 2 load bolts with swivel "feet" for supporting the bearing caps.
* All Girdles increase fluid capacity approx. 1/2 pint.
* All Girdles show a decrease in operating temperature, average of 15 degrees.
* Weighs about 7.5 lbs.
* Improves Undercarriage Appearance.
We machine all of our girdles in house to insure the highest quality possible. Each cover is machined using a 3 step CNC process which insures accuracy and high quality. Then each cover is hand deburred and inspected for the utmost in fit and finish. each cover is hand assembled and packaged.
