(1) Set of stock headers, meticulously ported, welded, Eastwood coated. Probably the finest set of stock headers available, includes crossover. $500.00
(1) TA66 Q-trim turbo built by Limit Engineering. Only used for a couple dyno pulls since the last check-up from John & Chopper. Includes both a PTE.85 & PTE.63 exhaust housings, billet inlet bell, & HD actuator. $1,000.00
(1) Pete Tomka cold-air kit, new in the box. 4" tubing from filter-MAF, 3.5" tubing from MAF-turbo. Perfect fit for the TA66 turbo listed above! $200.00
(1) Big Stuff-3 AFRM (Air Fuel Ratio Monitor), new in the box. This thing is awesome with all the bells & whistles. Visit the Big Stuff-3 website for all the specs. They retail for $700-$750 on the internet... $500.00
(2) Positive battery cable, p#12157383, $85.00 each
(1) Set of T-type center caps in chrome, p#25506048, $300.00
(1-pair) Chrome headlamp bezels, p# 25525090 & 25525091, $500.00/pair
(1) Set GN wheels, used and in need of reconditioning. Includes used center caps shown in picture. $200.00, prefer local pick-up but will ship if you're not in a hurry.
(1) Set of 32lb/hr. injectors with matching Turbo Tweak chip. Very low miles, just removed and ultrasonic cleaned & flowed at Richard Clark's shop. Here are the spec's from Racetronix's website: Racetronix - 621020 - 32 lb/hr Disc High-Z Fuel Injector $200.00
(1) Set of Budnik wheels & tires, approx. 100-miles & 3-track passes worth of usage!! 15x6 fronts w/ 205/75/15 Michelin tires, 15x8 (4" BS) rears. $1,000.00 The fronts have tires/the rears do not. Prefer local pick-up.
(1) Set of BBS wheels, brand new in the box. 15x3.5" front & 15x8" rear. Prefer local pickup, but will ship if you're patient for packing. These are just like what was on Cal Hartline's GN pictured below. They are not show polished like his though!! $2,000.00
K.
K.
