GN1 60lb Fuel Injectors and Chip Kit
Opie
I bought this set up from GN1 Performance . Does anyone know the type injectors these are? Also whats the gray wire for? There was not any instructions. Also when I placed this order I had stock MAF now have LT1 with translator so not sure if the chip I have now will work right. I think I am going to get a Turbo Tweak chip and need to know what part number these injectors are. I just cant seen to get the car to run right. thanks for the HELP!
http://www.gn1performance.com/proddetail.asp?prod=AFuelInjectorsandchip
They appear to be Siemens Deka/ Mototron 60# injectors... they are good injectors if they are. The grey wire is to enable window switch override functions on the chip... it’s not necessary to use it but adds some function. Most likely it’s a Bob Bailey chip... also good.
Sent from my iPhone using Tapatalk Pro
