gnx fender flares
movinfast
does any body have them on their car and if you do how much of a wider tire can go under them,or if you put them on does your original wheel opening still their..if you have a pic. please show.thanks
I bought mine off ebay around 7 years ago, they bolt up to the inside of the stock wheel well opening, so these that I have don't really give you that much more room. Currently running 275/55/16s M&H DRs on GTA fronts, I am running a 3/8" spacer on the rear, but it's not needed, I just use it to be able to use the black lug caps on the lugs, with out the spacer the extended studs go thru too far.
