Aftermarket
I purchased mine from jay's gn( danko) they fit "just ok" out of the box.. I spent approx 2.0 hrs each fitting,sanding,cutting off at the bottoms to fit and look perfect.i blocked alot of the gel coat off(probably a mistake) and epoxy primed,blocked and re-primed. I cut some fiberglass from the rear wheelopening and als0 added fiberglass in other areas. I wanted the w-opening to match the quarter w-opening..all in all i'm happy with the rusults,problem is "where are you gonna find many reproduction flairs,only a few companys sell them.. Good luck..
