GNX Style Dash
it's just a few wires- you need to wire up the senders for each gauge, as well as the power, ground, and light wires.
plus there is the speedo cable if running a mechanical speedo and a vacuum line if running a mechanical vacuum/boost gauge. every other gauge should be electrical to make things easier.
no real way to explain it other than to say to get going on it, and hope you can find a way to do it without hacking up the stock wiring.
