You can try turning on 2 psi sooner,that wont change overall volume,just sooner so you see higher pressures earlier.then you can increase initial that will change volume into the motor so there is more overall.you can also try increasing gas in the tt chip and reduce timing.eliminating wheelspin so it doesn't throw things off should be a goal as wellMmmmmm love how threads squirrel. I don't care about the alky plate thank you for your help spending my money.
I'll play around and post findings.
