... and just wanted to see how my readings compare.
Sitting idling in garage: On first crankup (cold), my O2's start out "too rich", then start showing readings around 10:1, gradually creeping up to 13.5:1. After it goes closed loop, the readings bounce from 13.4:1 to 14.4:1. When I turned on the A/C, the readings jumped up to (average) around 15.8:1. When I hit my alky "test" button, the meter dropped to 9.5:1, then recovered to over 18:1 for about 12 seconds.
First drive-around and pass: (No alky, 18# boost) I'm seeing the ratio *try* to stay around 14.7:1, but whenever I give it any throttle, it drops to around 10:1 or so. On the "pass", whenever I tromped it, the ratio went straight to 10:1, then bounced around a little at 10.5:1. On decel, it jumps up to 22:1, then recovers (after a few bounces) to 14.7:1.
Do you think the 10:1 on accel is causing the black smoke from the tailpipe? Should I get the chip burned for a higher ratio, like 11.5 or 12.0?
TIA!
TIA!
