Green Stripes?
GrndNatnl
Regal of the Dark Order
Looking closer at my injectors, after seeing a picture of someones green-stripes, mine are different. The stripe isnt green, its a blue color, and its up near the top, not around the fatter part of the injector in the middle. (No, they're not blue tops) Just a little blue-ish ring. However, if you go to www.KirbanPerformance.com and look under Fuel system stuff, and look at his green stripe injectors, those are exactly what mine look like. Notice its more blue then a green? I'm pretty sure now that they're Kirban injectors on the car now. But whats with the blue instead of green? All the other green-stripes I've seen have an actual green ring around the middle, wider part of the injector. Are they still the same?
Compare the part numbers to those on GNTTYPE.org. I believe there are 2 different 'green-stripe' injectors...one has 2 holes in the bottom which is rated at 30 something lbs@hr and the ones with 3 holes in the bottom are the 009's @ 42.5 lbs @ hr.
HTH
Jim
Mine are 30 lb/hr injectors, and they look like the 009 rings, but they're not a green ring, they're blue.
The same color the Tomco little blue rings up top, but of course they dont have the big green one in the middle. Look at Kirban's site, they're identicle.
