Gt6152e
DCVING 6
Is there any difference in this and a PT-61?
would a 3000 stall work with the GT series?
pt61 is 6152e , 3200-3400 would be better,
a 6131e would be a better match for a 3000
but a 3000 can work for pt61
fred
same turbo I run on my car...
I run a 3200 n-l art carr converter and this thing spools instantly on the street...
it will work with a 3000 but won't be as snappy...by far the most powerful street/strip turbo out there for the money... :D
fred
Don,
What is the power output difference between the two turbine wheels?
John Wilde said:
Don,
What is the power output difference between the twin turbine wheels?
Not very much...the 6131 is a limited build turbo and might make 25 horse less than the T-350 wheel (6152). I always like to see the 6152 because it will flow better on the exhaust side versus a big comp wheel/small exhaust wheel combo like the 6131
Thanks for the quick response.
There is a little stock converter issue. :tongue:
I have a related question...... :biggrin:
What is the difference between the GT6152E and the TE61 w/garrett .63 exhaust housing
I know the wheels are slightly different... but real world.... spoolup vs top end hp potential..... and when do either become better suited than the other.... i.e. @ what boost does turbo x become better than turbo y ..... but turbo x or y is much better overall if boost is kept below ??
Clear as mud?
some of you guys get too caught up in specs sometimes :eek:
the TE-61 is NOT the same as the PT61...two totally different compressor wheels...the new 61 is a Garrett GT comp wheel used on the GT35R ball bearing turbo...according to the compressor map on that turbo and from my personal experience, that turbo is most efficient (almost 80%) at 20-22 lbs of boost....it's still nearly 76-78% efficient at around 25 lbs...then it starts to fall off...but it's nearly 70% at 30 lbs...plenty of sport compact guys out there run this compressor up to 35 lbs all day long and they are making nearly 600 hp to the tires...so it's a really good compressor wheel...the TE61 wheel doesn't even come close...
That makes sense. There are a few EVOs running around making over 600 whp with the GT35Rs. I have a brand new PT6152 sitting in my engine bay that I can't wait to push 20 psi out of.
