SignUp Now!My brother has the gta rims and he uses 275/50/16's MT's and his car hooks well. And they also look good as well.im trying to find what drag radial im gonna put on my 16 gta rims if u have pics post up tire size thx
I'm sorry, they are indeed a 255/50/16afik they dont make a tire that size
mickey makes an et street radial 255/50-16 ( equiv to a 26.1")
with front gta rims may rub frame on some cars and might need a thin spacer
and they make et street radial II's in
315/45-16 ( equiv to 27x12.5 at 27.2") forget it with an 8" gta
and a 295/50-16 ( equiv to a 28x11.5 at 27.7")
needs spacers with a gta rim and then you'll need to roll the fender lip unless you like the car jacked up with airbags
they fit with the 8" gta
bweavy has a widened gta with back spacing that will clear frame but will need lips rolled if you like the car low
when mickey first came out with the 255/50-16 i ran them on my 86 with GTAs front rims (had a 200-4r trans back then) 1.50 60s were common off the t-brake, and using OD would run them out over 127 in the 1/4 at mid 10's .
