(gu6) 342 geared rear end
we2man
Im having a new rear axel installed are there any identifying numbers on the axel tube? because i dont want to get ripped a new one!
forget the codes..
pop the cover an count the teeth.. a little division tells you the gear ratio.. and while you are looking in there, you can see if it's a posi and check the general condition of everything.
forget the codes..
THANKS!
