Guage connections
billygeg
I got my guages today. I bought them off a guy from here. I need some direction on how to connect them.
The first one is a oil PSI Pro-comp auto meter
It has 3 wires. Two I know are the power (red/black) which jump to the water temp guage. Do they connect the the hedlights for night vision? The 3rd wire is a longer green wire that I need to know where to connect in the engine compartment.
The second guage is a Faze 280 degree max temp guage, This guage has 5 wires that come off it. two are black and red that are defintely power. Two of the whites are power as well that are connected to the two wires that I mentioned that jump to the oil guage. I just need to know where to connect the last wire in the engine compartment.
Last is a Faze 30 lb max Boost guage. This guage has a vacuum line attached to it along with 2 power wires. I know where the power wires go but need to know where to connect the vac line.
There is also a little led right next to the boost guage with red and black wires attached to it. I assume it may be some sort of a visual alarm maybe? If so where do these two wires wires attach too?
Thanks guys!
Try this one...
http://www.egauges.com/pdf/AutoMeter/665h.pdf
and this... Post #30 in Basic Hot Air "sticky" section...
Installing Boost Gauge...
On the front of your intake over near the water neck, and water temp sensor there is a plug. Remove the plug in the intake, and it will supply you with a direct port for you to get your boost gauge reading. Along with your Boost Gauge kit there usually comes brass fittings. One of those fittings fits right into the intake, and provides you with a tight Boost Gauge seal.
Look here...
http://www.engraver1.com/help/intake2ETC.gif
Connect to #7 -plug, located on the front of intake.
