Guy, (Lou's new lamb)
cruzn57
Still plays with cars!
car ran great, I believe he went 11.0 in it and RJ managed a 10.70 in also
heres a pic
IS THAT AIR UNDER THE RIGHT FRONT TIRE??
heres a pic
Looks like a little daylight, I see it too! Very clean car. Nice run too!
The guy in the foreground( TA shirt) is RJ, so I know it was Guy driving on this run
Congrats Guy.
Details. What did it MPH? how much boost? Would like to see time slips.
Mike Barnard
I didn't catch the speed
but
Lou was there, tuning, he will know,
I do know it broke on the last run, maybe lou or guy will speak up.
sure is a clean car!!!!!!!
I was trying two different chip combination's. one was using Eric Marshall alky chip & the other turning the alky way down a using C-16 chip. The car has had a gremlin I was trying to chase down . It would miss a bit on the 2-3 shift. I was adding & subtracting fuel & timing trying to pin it down till finally it quit. The cam sensor pin sheared off . But the ECU was also found to be a problem after the cam sensor was replaced.Hopefully its fixed. The best it could do in the heat of the day was a 10.82. 124.58 Guy is still trying to learn how to drive it. That will come in time.
Thanks everybody!
It was a great day for me.
I'm praying for Scott's speedy recovery.
Lou got the car fixed before he had to go back home and we still have three weeks of racing left out here so I'll try to hook up with RJ or Nick and get the car out to see if we found our gremlin. :confused:
(I think we did :smile:)
Guy,
Thanks again for letting make a pass in your car. It's been a while since since I drove one of these cars with Powermaster brakes, but the peddal felt pretty soft to me. That may be the reason why we could only hold 3 psi at the line. The last time I ran the car we could hold 8 psi at the line. You may want to bleed the brakes or have it checked. With a better 60ft and the gremlims worked out the car will easily run low tens.
Guy,
Thanks again for letting make a pass in your car. It's been a while since since I drove once of these cars with Powermaster brakes, but the peddal felt pretty soft to me. That may be the reason why we could only hold 3 psi at the line. The last time I ran the car we could hold 8 psi at the line. You may want to bleed the brakes or have it checked. With a better 60ft and the gremlims worked out the car will easily run low tens.
Hmmm, come to think of it, you might just have something there......we actually had the back drums off and prepped the pads before we went out but a brake bleed is probably in order.
I'll work on it this week.
My boss thinks his WRX will be running by Saturday so there is a good chance we will be out at Speedworld for some fun. I wonder if it will be a Darkside night........**shifty eyes- evil grin**
I will be there Saturday for Arizona's Fastest Street Cars. I may stay for the night race as well depending on what they have going on.
Nice to be hitting high 10's without really launching!:D
Would be cool ot see the time slip stats.
Those are a little embarrasing... kinda like the burnout I did in reverse...........
If I can get them to copy a little darker I'll post a couple up.
The printer at that drag strip REALLY needs a new ink ribbon!!!!
