Ok I know I keep posting and probably pissing off a few people but here goes!
I have a 1984 Grand Nash and it has many mods on it.
rebuilt motor, not sure on internals, but I know it has ARP studs
New TA33 turbo running at 16psi
Walboro 340 pump and hot wire kit
Accell adjustable pressure regulator
Cold air intake
Poston headers and crossover pipe
Mease downpipe
Ok the problem is when it starts it surges real bad, then when it warms up it gets real hot I mean real hot!!! It fries the plug wires on the passenger side:frown: The car has some power but with the mods it is slower then my bone stock 84 WH1
I noticed today when you turn the key to the run position the fuel pressure shoots up to 55psi then drops rapidly???? I have it set to 45psi when it is running? I was also wondering with some of the mods I have should I get a chip burned for it or does it really matter?? I would really just like to get it fine tuned so I can drive it for more then 20 minutes with out it crapping out or fouling plugs left and right
Any help here??
Cold air intake
Mease downpipe
Any help here??
