SignUp Now!Originally posted by oldtimer
Is the S10 steering box and pitman arm a straight forward bolt on modification to a GN or is there some adaptation required to hook it to the steering column. If so what parts are required ?
George
Originally posted by turbodave231
I used a manual steering box off an S-10 truck with the pitman arm off the GN. You can take that PS pump off and run a shorter belt.......but you already knew that!
Loosing the P/S really cleans up the underhood plumbing!
Dave
