HARD BRAKE PEDAL/BARELY ANY BRAKES
Logan Twitchell
THE BRAKE PEDAL IS HARD, I CAN ONLY PUSH IT DOWN MAYBE AN INCH AND CAR WILL BARELY STOP BRAKE LIGHT IS ON AND IDEAS WHAT IT COULD BE. COMPLETLEY CAN NOT DRIVE CAR DUE TO NOT ABLE TO STOP CAR.......ANY THOUGHTS
l had the same issue...then I converted to vacuum brakes, and the drivability and my confidence, improved dramatically!!
I had the same problem. It was the accumulator ball that was bad. They are pretty inexpensive. Pretty sure I got my replacement from Gbodyparts.com.
Time to junk the power disaster. Be thankful you didn't wreck. Upgrade to vacuum or hydroboost. Don't waste a penny on even trying to fix pm.
