Hard Vac. Lines
BFlat
I’m wearing out this list with questions, but I’m almost done putting stuff back together. The hard lines I took off don’t want to line up to go back on. The 2 hold-down bolts are installed. Don’t think the lines got bent, but something is different. Only thing I did was to install a power plate and an IAC relocate. Do I start bending & hope they don’t kink or break, or do they make replacements? I can’t find any for sale. I want the lines to be like factory. Thanks.
take the bolts out , put the lines to the vac block then figure out how much you need to put a spacer under the tabs and put a longer bolt in
bolts are m8x1.25 and you can use a larger nut as a spacer
or just bend them up to reach
Thanks. I’ll try that. Don’t think I’ll be able to raise the front tab with a spacer by much because of the IAC angle boss, but I’ll try it. I can’t figure out why neither the front or the back lines don’t line up now. The back ones are too far forward. Darn. This should have been so simple.
