Harland sharp 1.6 rockers
Sweet6
If you run a stock cam, can you still run the stock pushrods?
TIA
Souldn't be a problem, the geometry may change a little bit but, that's easily corrected with a change in push rod length. Summit sells an adjustable push rod that you can use to measure the length, easily done!
Frank
Frank
The Harlands are adjustable. So adj pushrod is not needed.
Well A BIG HOWDY to you Julio!
You might wanna explain to me just what the hell yer talkin about? In the 1st place I didn't recommend Pearcy's old adj pushrods, I simply said that Summit has adjustable rods (which are michs) that are made to determine push rod length. 2nd you seem to infer that either the push rods or rocker arms on the Harland & Sharp rockers are adjustable, either of which is a bad idea. Quick question (what's yer cut on these things). Hey! I thought you were still tryin to help folks.
Dont sell em. Dont make a .01 on them. Geat product from an established business making these.
Never mentioned Pearcy.. The comp adjustable pushrod is used to get you a length. The rocker does the final trimming. With stock cam and stock heads.. the factory pushrod is perfect. So no need to mess with that.
All roller rocker arms are adjustable. This is why you dont need to play with the adjustable pushrods. Even the ones you made and where going to make and try to profit off of. ;)
Oh Julio! That is SO beneath you! HMMM! Well! Maybe not but who cares? HA!
