Should be a "Main Spark" table that is rpm vs MAP based or rpm/load based.
For fueling, it depends on if it is speed density or MAF controlled fueling.
If MAF, then there should be several MAF tables to adjust...which can be tricky. I haven't done one for a truck exactly like yours, but for all other MAF vehicles, you have to alter the frequency #s in the MAF table which will cause the computer to calculate the air mass either lower or higher for whatever frequency its reading at the different rpms/loads.
So lets say your RICH at IDLE and the MAF shows 8gmps.
Looking in the MAF table at "8" shows a frequency of say 4.65.
To make it leaner, you would make the value at "8" something lower, say 4.25 and then also adjust the adjactent values for 7 and 9 to be just a little lower....do it in very small increments until you are comfortable with the effects of changing it...it can be very time consuming.
Now if its speed density, its much easier..there should be a table called something "Volumetric Efficiency" it should be a combo of rpm, load, MAP based as well. Just go to the cells that correlate to your rpm/load/MAP reading where you need it to be leaner at and lower the number in that cell...or raise the number to make it richer.
I usualy use the BLM number at that load to help determine...for example since perfect is 128, say your BLM is 118.
Then you % off is 118 / 128 = .92 or 92%.
Multiple the number in that cell of the table by 0.92.... If its 80.0 then make it 80.0 * .92 = 73.6 which will lean it out by 8%. That will make the BLM about 128 where you want it.
Hope that helps
