Have some questions about MAFTPRO hardware!
turbobuick1
I've tried searching for threads related to this but kind of got impatient, so hopefully someone who has experience with the MAFTPRO can help. I purchased this system to accomodate future mods after my stock MAF died. The car is damn near stock, with the exception of a 3.5" cold air kit I fabricated (no provision for MAF), and 36lb injectors that I installed to replace failing stock injectors, and a TurboTweak chip to acommodate that. Bear with me, I'm new to this game:
1) Since I'm looking to run in speed density mode, I know I need a GM 3 bar MAP sensor. Where can I find these for cheap, and I suppose I'll need a pigtail for it, where can I find that?
2) I understand to run the MAFTPRO to its max potential, a TunerPro chip and Wideband 02 sensor are required. Are the chips burned for one set of injectors? Like if I bought a used one that someone was using with 42lb injectors, would I need to send it in to FullThrottle and have them reburn it? Anybody know how much that costs?
3)I'm pretty confused on my choices for wideband 02s. Can I not just buy a basic $60 wideband 02 sensor, and wire it into my MAFTPRO? Do I need to purchase a complete $150 LC-1 Kit?
Now, I know this is extreme overkill for an essentially stock GN, but all I want right now is to run without a MAF sensor and tune this car so it run's like a top. Any input,advice, experience is welcome! Thanks guys.
3bar map from fullthrottlespeed.com ,GM or razor at alkycontrol.com . tthe buick vendors are probably cheaper than you'll get from gm
if you have a GN with analog dash the 3bar replaces the stock 2bar under the hood , no need for a pigtail unless you want to keep the 2bar to drive the stock analog boost gauge
if its digital the pigtail harness for a map sensor is under the hood and can be made to operate can be made
not sure how well the maft pro works with a std chip like the TT but im sure it works best with their chips
the maft pro wont support a bosch sensor only you need a wideband unit with a sensor and one that has an output of 0-5v ... innovate lc-1, plx ,aem or whatever else maft pro will work with . and really dont need the wideband unless you want to run in a/f tuning mode
running in speed density mode with a map sensor will eliminate the need for a maf sensor
really you should have asked the questions before buying at fullthrottletech.com
http://www.fullthrottletech.com/showthread.php?t=1364
