tpivette89
- Mar 27, 2002
heres a brief history of the events that lead up to my current problem:
about a month ago, the car ran great... no problems. i pulled into a gas station to top off the tank, and when i was done pumping, i fired the car up and all of a sudden it ran like crap. it was hesitating all throughout the rpm range. so i limped it home, did a quick fuel pressure test and found it to be below where it should be
i suspected a fuel pump, replaced it with a GM SyTy pump, went to fire it up and now it wont start. the car cranks, and it sounds like the pump is priming when you turn the key to the "on" position, but im getting 0 fuel pressure at the rail
any suggestions?
any suggestions?
