THE BLACK MAMBA
- Nov 9, 2007
I`m having problems with my fuel pressure gauge bouncing...what can cause this
SignUp Now!Well i thought that too...so i put some more fuel in it...and still the sameMy guess is it's starved for fuel. I was using the same KB gauge when I was running the fuel out of my tank. Before it ran dry my gauge did the same thing. It bounced more the lower the fuel got. My $.02
I have not monitor the drop yet...i will checkWhat does it do when you turn the car off ?
Should slowly bleed off. If it drops fast it maybe a check valve in the pump if so equipped or a regulator or injectors bleeding down.
Is the gauge filled or does it have a damper that might have broke?
How about running the pump with the engine off through the test plug?
Its a new one, but i will change it this weekend....I can hear the fuel pulsating in the gaugeMy KB gauge shows lower pressure when I have about 1/8 tank of gas. Maybe your fuel filter is clogged? Can't replace those too much.
That was the first thing i did, was removed it from the mount and still did the same thingVibration?
If you remove it from the mount and hold it in your hand does it still do it?
Due to overboost problems i usually get out of it at #15psi, and its hard getting a accurate reading on the fuel pressure gauge due to the needle moving alot....if you listen close you can hear the fuel gauge pulsating...How does it act under full boost?
