you need to replace the turn signal assembly
http://www.ebay.com/itm/New-Turn-Si...ash=item3f5ad1e502:g:qpwAAOSwuYVWmdtH&vxp=mtr
you may be able to repair what you have with parts from the new one but probably better to just replace it all
pull strg wheel , (need a strg wheel puller)
depress lockout plate , pry up snap ring remove plte (need a lockout plate remover)
remove cancelling cam
remove turn signal lever linkage (screw)
remove hazard switch.. small phillips (yours is broken so may not be necessary)
remove three screws holding the signal assembly
remove lower dash trim
unplug the long flat connector at pass side of column and slide connector off the tabs on the column
remove the four 1/2 bolts from column support plate
remove the two 15mm bolts holding column up and remove support plate
make sure column tilt is in straight position
now you should be able to pull and slide the switch assembly out
slide new switch assembly in and put it all back together
