head gasket ?
TKGN1
Will felpro 9441pt gasket be fine to use on reciever grooved heads (champion irons). I usually use the 1007 but wanted to see if the 9441 would be fine, better, or worse. TIA
Your going to need and mill the heads flat if you want to use the 9441's.. as far as better or worse.. thats a tough call.
Thanks, I was looking at cost difference between the two and wanted to see if the 9441 would work. I havn't had probs with the 1007, just gets expensive after pulling the heads a few times.
But if I have to machine the heads I don't think it would be cost effective.
