Ok so here is the story...my GN has sat in the garage for the better part of the last 4 years. I drove it about 2 months ago and parked it again. was doing some work on the turbo and getting it ready to drive. I was toping off all the fluids when i noticed the coolant was about 6" low in the radiator, so i filled it up. started the car and thats when i noticed coolant was leaking out between the turbo and down pipe which is the gasket i had just replaced...i know that needs more work. but my main concern is there is coolant coming out of the header. did a compression check passenger side had112,115,119, driver side 120,120,120. all within 10% no coolant in oil or oil in coolant that i can see. all the plugs looked clean and dry. what kinda tests can i do to narrow my problem down. could it be the intake gasket? cracked exhaust valve? head gasket?
